Originally posted by enoeske Most lenses change focal length ever so slightly when the focus changes. Assuming the aperture remains physically the same size, this could result in a change in exposure.
I understand there may be some change in EV with non constant aperture zooms but I'm having this occur with primes.
The exposure change does not occur if the near and far objects are similar in reflectivity. It only occurs when there is a reasonable contrast difference.
Rack focussing from a dark foreground object to a light background object and back again causes a brief change in exposure which then settles back once the rack focussing stops.
If, for example, I rack focus between two middle grey objects no change in exposure occurs. This indicates to me that this symptom is not directly caused by a change focal length/lens speed.
It seems that the camera briefly loses AE-L and resorts to auto mode then back to AE-L again once I finish rack focussing.
