Originally posted by Anvh Am i that blind that i can't find them?
I know you can lock exposure and things like that but i've no idea how to select the ISO or Shutterspeed, first time i hear you can do that with the K5.
Can you explain that more or have a link?
If i had the money i would just buy a RED Scarlet and call it a day but don't have that kind of funds and knowledge yet for it.
Here is how I manually set iso, shutter speed in the k-x. I dont know if it works in k5 or k7 but I assume it should. Turn the camera dial to P mode. Also ensure green button is programmed to ensure p line gets set to shutter priority [tv] or aperture priority. While in P mode set whatever iso and shutter speed u want and press the ae-lock button [it shud be programmed to lock exposure and not focus]. After this turn the camera to video mode and immediately press the ae lock button again [u will not need to do this when u r using a manual lens as it continues to be locked but when using any af lens the ae lock gets unlocked within a few seconds of going to video mode so its important that u immediately press the ae lock button to ensure the shutter and iso u set in p mode is retained]
By the way under p mode u cannot manually set a specific shutter speed and u need to point the camera at a light source to get a desired shutter speed. its a hassle but u cant do anything else. So say u want a low shutter speed point it at some dark region [it will also be a good idea to set metering to spot instead of centre or matrix metering] the shutter speed numbers will keep changing rapidly. The instant u get a shutter speed number u want press the ae lock button. Ensure the lowest shutter speed is 1/25 as if its anything lower and u go to video mode the shutter speed lower than 1/25 gets disabled and video goes in to auto shutter speed mode. Iso however continues to be the same though its the shutter speed which will keep chaging
By the way any color scheme u retained in p mode such as natural or portrait gets transferred to video mode. Also if u wanna shoot cross processed video ensure in p mode the jpeg option is selected and chose cross processing as an option. So when u turn to video mode u get to shoot real time cross processed video [for that retro cool look]
U already know u can change aperture once in video mode but if u want aperture to also be set under P mode then programme green button to P line which will also set aperture and shutter speed. if u r using a manual lens whatever aperture set on lens will be used to shoot the video and not wide open
By the way the shutter speed and iso and ae lock get disabled the minute the camera switches off. So ensure when you are shooting video you dont switch off the camera and set the camera to go into standby mode when not in use. So say u shoot a video and wanna have same settings next day then ensure camera is in standby mode so next day when it comes out of standby the shutter and iso continue to be the same.
Anyway the method I gave works for the K-x and as I havent used the k5 or k7 I dont know if it will work but suggest you try and see.
