Originally posted by kadajawi Yeah, the difference between h264 coming from a camera and h264 compressed by a good encoder and good settings is huge. For high quality h264 you need a lot of processing power.
So basically the K5 is better for video? Does it pull together pixels or will it only use some like the K-30? What is the maximum ISO? I think somewhere I read for the 30 it is 3200.
Correct, K5 with mjpeg capture/save full frames, where as with h.264 only the changes between the frames is recorded to save space but it cost a lot of power to get it perfect.
K5 is therefore most likely better for editing since it capture more, it does pull the pixels together but the whole width of the sensor is used, don't know if that's the case with the K30?
No idea about the highest ISO of the K5 and video.
