No No No .... this is just for getting the camera to light-meter the scene ... if you give the right input to what
the video mode might need for a correct metering ... But you may forget about that when you point the camera
well enough ... and then use the
Green Button ...
I have reason to believe
(in doubt again now, just a little) that the
Green Button is a short time automatic
exposure metering for the situation you want to shoot.
In professional camcorders you have a switch and a button for that: The switch says: On & Off to the automatic //
manual exposure - And the button gives you quick access to auto-exposure just for once - so the next second you
can change the f-stop on the lense ring ...
I think Pentax had the same in mind because you need a reference metering that shows you what the camera
wants as an ideal expsosure. But this
Green Button works good enough only (I still have to find out) when you
first choose the right area for your exposure metering - spot or medium I guess ist always best.
(I am used to
zoom in always - with my parfocal lense and it's all the same focal length - push the quick exposure button ...
and I also get the right manual focus then of course)
In my case now - completely white faces because of strong sunlight and a lot of shadows around it - spot-metering
into a sunny face could have helped ..... But we may also adjust that bad aperture by using that extra
compensation
plus minus button .... so the
Greeen Button gives you just a very first quick reference metering only ... then you need
to controle that .... (I was terribly mad mixing my old knowledge with K-5 work-arounds again this time - but I hope never
again will do that failure-confusion-misinterpretation ... Please get it, old brain !
Quote from DPREVIEW-board:
Can anyone help me please? I am a proud owner of a new K5, but I'm struggling to get my head around the green button on the back of the camera. Can someone give me a simple explanation of a) what this does and b) when would I use it?
Almost 100% of my pictures are done in TAv or M mode; I don't think I've used any other modes on my K-5 other than to see if they work.In those modes the green button is useful if you've changed light conditions - perhaps shooting a few times into a sunset, then turning around to take a picture with the good sunset light. You hit the green button and you've got a setting that works, maybe not exactly what you want, but something that will give you good exposure. You then turn the dials 'x' clicks each to get the setting you want and you're done.
It sounds more complicated then it is, in reality you can do it all in a second or two.
There is no somple explanation of what it does, because it does different things in different situations, and different things on the same situation depending on how you have set your camera options.
But the one indispensible use I have for it is when shooting in M mode, which is to say, when shooting, since tht is the only mode I ever use. In M mode, hitting the green button causes the camera to automatically choose an appropriate shutter speed for the ISO and aperture I have selected. basically, to do with the touch of a button what Av mode does automatically, but the advantage of my way for me is that the exposure is then automatically locked until I change it, whereas in Av mode it will keep fluctuation in response to all sorts of factors that may or may not be relevant to me.
EDIT:
Pentax tried to make the video mode similar to photo mode - that may be the root-reason for this stupid non-manual
state of old Pentaxes ... They didn't switch to good old video-knowledge ... but wanted photograpers to handle video as
they do it in photo mode ... That may have been the big confusion - They did a lot of work into a complicated bad direction
intelligent minds' work in progress .... I slowly get it why they went wrong with these meaningful dillusions ... ( ? )
Just think of what could be possible with hyper manual mode that could work in video as well ! Maybe this is a hidden truth
we have not discovered fully yet - bevause nobody did find out yet ? New Hope to come ?
This is for long and lonely nights to find out maybe ... ?
