Originally posted by JohnnyXD What is that?
well, a bit off topic, but here it is:
when filming with an M lens, and in manual mode, whatever you set the iso value, the k01 will disregard it and choose an auto iso value.
which is ok, as the k01 is quite good in higher iso's if needed. BUT it causes your exposure to adjust itself when panning e.g. from a lighter to darker situation and it means you actually cannot really control the exposure (except for +-ev).
Someone had a work around for it in a prior post, pointing the cam in a certain "light" direction and then lock the iso value (without knowing what it is & then adjusting the other parameters) but it would be helpful if it worked out of the box... especially with a ton of M lenses back home...
I you happen to have both an M and a A lens, you can try it out..
