Sorry to say, but this is the sad truth about mechanical sensor SR in K-7 as well I guess in K-5 and K-5II
You can use the old SR for photos very well .... but for videos you may use it only with ugly side-effects
that will rather tell you to put it off - mostly.
If you do an interview or just a steady shot you may use SR to reduce your physical micro-shakings.
But as soon as you move the camera in a panning way the SR cannot controle the movement anymore
Only if you do very, very soft movements the sensor SR can eventually be used while panning - if you do care.
And it is logical when you really think about it: The sensor moves into the opposite direction to neutralize
the loss of tranquility - out of the balanced target - when you move away and pan somewhere else. The sensor
is drawn to the limits / to the farest corner ...
When you stop your pan - the SR now has to return to it's usual central position - but this looks very ugly and
cannot be used. You can only cut off this last counter-movement - if you dare - but mostly this is only possible in
quick cuts for modern and dramatic scenes, etc.
When you try to do smooth and calm impressions the SR cannot be used successfully unless you just do direct
and still shots only ... I admit this was a pain for me to realise and I do hope the modern Movie-SR does better,
which is added since the K-30 and K-01 ... The new K-3 got it too.
(But don't forget: Movie-SR got certain negative side-effects too)
I have done a test with active SR on my K-7
Part 1 - It can be used
Part 2 - shows what cannot be used at all.
