Originally posted by Adam Grunseth I will be shooting this project at 24p. However, even at 24p, I can't seem to set the shutter to 1/48.
Cos it's not there
The only DSLR's I've seen that do 1/48th, or even the correct shutter speeds for NTSC, are the 5D, and Canon's with Magic Lantern installed.
It is something that needs to be changed in the firmware of all video capable Pentax camera, along with being able to select the 'native' ISO's, Which the camera can use in Program mode, but the user can't in Manual exposure mode.
Originally posted by Adam Grunseth I would like to be able to record from the HDMI port an uncompressed signal for a more robust codec while editing.
So do the rest of us!
Unfortunately it's not yet possible, again this is one of the Firmware gripes, and not just for the K3.
Nikon have begun offering 'clean feed' HDMI, and it's again a Magic Lantern thing, along with the GH4 and Sony's upcoming A7s.
Ditto what John said regarding heat issues - I've shot several hours at a time on my K-01 and never had a single heat issue, I've found no reports of anyone having a heat problem on a K3 ( and have been looking as it's my next camera )
Originally posted by osv you'll need to be up to speed on film-style shooting, because you probably don't have a parfocal lens for the k-3.
Get a 'classic' or 'Full Frame film' Sigma lens, all of mine are Parfocal, so operate the same as the Zooms you're used to on the ENG cameras - Snap in, focus, snap out.
You'll need a Matte Box to control flares
The Sigma 28-200mm f3.5-5.6 is a damn good lens for video in my personal experience - I find mine to be a better video lens then it is a stills lens.
On the CoDec - it's the same CoDec as used in the K-01. I'm in the habit of shooting in the Muted profile, with the Contrast and Highlights set to provide a really flat image, and then control my lighting so that the vast majority of what the camera is seeing is exposed within the dynamic range of the sensor and CoDec. A USB/DMX controlled dimmer pack for my Redheads doesn't hurt
Outdoors can be difficult, unless you have a bag full of ND's and Fleckies or Silks to shade the talent.
However, if you can stay withing the exposure range of what the CoDec can deal with, you can get very good vision out of the Pentax cameras.
That lack of clean HDMI output, is probably the most frustrating part of owning a Pentax Camera.
