Originally posted by Sparkle You just do not get it!
Yeah I do, but you missed the 'also' part of it - sure, the literal meaning is obvious, like the first layer of lolz on Big Bang, but there's more behind it that you have to be a science geek to 'get'.
Originally posted by Steve.Ledger Almost anything would look OK at your 360p upload.. Why not publish a 1080p version???
Bandwidth, as in , I ain't got none, least not till the NBN fibre optic is connected - too far away from the nearest exchange to get decent value for money from a DSL plan.
Fibre doesn't have the same distance limitations as Copper.
I'm sooooo looking forward to proper internet speeds.....
As is, everything I upload to Vimeo is set to 1024x576 - true widescreen PAL Std Def - you should have the option to play it at that resolution - is the "HD" in the bottom right of the play Blue or Grey - Blue should result in a 'HD On' message appearing over the player.
Kadajawi: Those news shooters not liking 5D's,.. I reckon that's more about the lenses then the bodies. ENG Zooms are all Parfocal, Canon EF Zooms are all Varifocal -> one of the advantages of classic Sigma FF K-mount zooms, is that they're Parfocal - you should see the look on some peoples faces when you hand them a K-01 with a secondhand Sigma zoom,... and they rack the zoom back and forth, and repeat, pause, and repeat, and repeat, because they don't believe what they're seeing, and check the AF is off.......
The 'Kilter' scene -
'Demented' draft 02 -
The punk rock song is pre-colour correction (was doing that today) and pre swapping the camera audio for the proper pre-recorded sound.
It's rough and nasty, and that's the way it's meant to be for a punk band.
