Originally posted by grispie Remember that the Sony A55 had a mechanical IS for video. The next generation Alpha's also turned to software based IS for video.
Same as pentax.
I would suspect Sony's issues related to e.g. heat, noise or battery life.
Now they have optimised the system, reverting back to mechanical IS.
Maybe pentax just doesn't want to take any risk with heat issues or other, as they feel the system is not mature for use while recording video and as a quick explanation put the noise issue forward.
Maybe, just maybe the noise refers to sensor noise due to heat? I have never bothered to try recording video without SR to see how the sensor heats up then, but maybe that is the noise they were referring to? It'd make more sense. With sensors that don't heat up as much in the first place maybe that's less of an issue now... clearly Sony thinks it is, because they don't have a problem activating it anymore.
Olympus didn't have SR in video at first IIRC, but fixed that through a firmware update. Haven't heard about problems there either.
If it is really the noise the SR system makes, as in audible noise, clearly they should understand that users for whom audio is a concern will record audio externally, while others may use just some music to cut their videos to. If you use the in camera audio, then clearly audio isn't too important, and the bit of noise (which I rarely, if ever, heard) won't be too much of an issue. The improvements in image quality are clearly worth it using SR.
