Originally posted by richandfleur On one hand they don't know a heck of a lot about it, and on the other they have a natural eye for composition etc.
I'd actually argue that to be un-true - maybe 'less correct',...
I've noted a lot of Photographers frame with a lot of room around the subject, which is fine in stills where you have huge resolution and can crop down.
But in video, even HD and 4K, the framing for TV and Film is much different - We Cinematographers tend to cut off the tops of heads, or the sides of a face, if we can get more detail and more of the audience looking where we want them to be looking. We do the cropping or framing in camera because to do it in editing means a loss of detail.
A picture tells a thousand words right?
That means Cinematographers start at 24,000 words a second...
Originally posted by grispie Yesterday evening i was reading on the net that to get the best quality 25fps from my sony A77 was to shoot 50i at 24mbps (instead of 50p at 28mbps, these are menu choices..), put it on a 25fps timeline in premiere & it would automatically become 25p. The idea being that less fps (25 in 50i) are pushed through 24mbps than 50fps through 28mbps, thus retaining more details.
That's one of those 'technically correct for Compression' comments.
If you're shooting close ups of talent that aren't moving about in frame much, sure, give it a go./
But any decent level of motion, you want as many frames as you can get, at an appropriate shutter speed to preserve sharpness as needed.
I use higher shutter speeds when filming sports, or when there's so much light that even the ND's don't cut it down enough.
And as Kadajawi said above, the conversion process will give you a massive hit in rendering, his solution of shooting 25p is very much the best option for 25p delivery.
The absolute best way to shoot 50p and not loose a heap of data in the CoDec, is to use an external recorder.
Anyone checked you can turn the overlays off on the HDMI for the K-3, K-S1 and K-S2 ?
