Originally posted by Steve.Ledger 100% sure, and your K-5 screen shots prove what I was saying.
I'll upload some OOC samples to DropBox..
I do think the parts that are in focus are relatively sharp. Not 1080p (well, the screenshots are sadly sampled down to 720p), but it's not too bad, given that there is no sharpening applied. Everything sharp, in focus, no. With a lot more light I could get closer, but it won't match a tiny sensor.
Originally posted by richandfleur That shot above with the waves coming in will confuse the h3ll out of the codec. The bit rate is not high enough for a shot like that to ever work on Pentax.
The K-5 can handle that. No problem. Newer Pentax cameras can't, that's true. But I think many would fail.
Originally posted by PiDicus Rex That was similar to my first thought.
They can be, but it takes a decent lens, and a closed down Iris, which means a heap of light ( same as on an ENG camera ).
Woah, that's horrid.
Lemme guess - cheap LED Parcan clones? HATE, WITH, PASSION.
Shot some burlesque before new year with those, absolutely rotten. Got a Mate-ette to book proper tungsten Par's for her's a couple of weekends ago, amazing, skin that looks like skin, not like blue plastic.
Will drag 'em in to Edius and take a look
I don't know what LED lights were used, but... it looked horrible. And it was way too focused... one point of the stage was always blown out, no matter what was standing there.
I suppose you'll never be able to share those shoots?
Originally posted by Steve.Ledger I have what I consider pretty decent lenses, but I don't have a DLSR that has decent video.
You're 'flyscreen' comment the other day was spot on. It's exactly the effect you get from Pentax video.
Rather than cropping the sensor at 1080, they remove lines until you get 1080p. Crikey, have you tried 720p mode, it's freaking scary bad...! Any line which isn't perfectly horizontal is like a flight of steps.
The word 'hideous' comes to mind.
So actually, my opinion is that no, a decent lens is not enough - more is needed in decent video engineering from a camera which should be quite capable of it.
Cropping the sensor at 1080p would mean a very, very tight crop. That wouldn't work for me. I already don't like the crop the newer Pentax forces onto you. It would be nice to have, if you need to zoom in for once. The solution is to read the whole sensor, and then resize it. But the processing power and the sensors Pentax used so far probably won't allow it. Nikon IS doing it (maybe not completely... but to quite an extent) with their newer cameras, so the Fujitsu/Sony hardware should be capable of doing it. One problem with newer Pentaxes is I think also the lack of an AA filter... that makes lines even harsher, and the AA simulator doesn't work during video.
Btw., as to that DSLRs can't produce sharp video... what about the NX1? I know, technically not a DSLR, but the only thing speaking against having that hardware in a DSLR body is that Samsung is not making DSLRs, and may not sell the CPU and sensor to other companies. Wouldn't it be great if Pentax and Samsung would be partners again? Samsung provides the sensor and processor, Pentax does the lenses and SR. Pentax creates DSLR cameras, Samsung mirrorless. A match made in heaven.
