ETTR,... not a fan.
Sure it gives you more range in the shadows, but you loose the highlights completely.
( I really need post an example of as-shot and corrected from a video that I did a while back,.... )
Originally posted by LensBeginner You mean too much light is bad? I thought that it would only increase the ISO and reduce DR...
Those are not the same.
You get maximum Dynamic Range out of a sensor when it's operating at it's 'native' ISO, or in proper video sensor terms, when it's operating at Zero dB gain applied.
I've not seen any official figures for which ISO setting equates to 0dB gain on a K-01 (or any of the Pentax cameras), or if any setting has attenuation applied.
My gut feeling based on the amount of noise in the image, is that it is likely to be one of the three lowest settings - 100, 200 or 400.
800 ISO has some noise in the image, but it's a good noise
Over exposing the sensor will reduce the dynamic range of the encoded image.
Originally posted by LensBeginner 2. the compression renders it useless unless you can record raw video?
When you look at the K-01's vision, either when opening the files in your NLE, or via a waveform monitor attached to the Analog output, the signal you get is not clipped to 0 and 100% IRE, it instead includes information from about -20 to +125%.
So where Canon's etc hard clip the data at 0 and 100, throwing away picture information, the Pentax cameras are preserving the dynamic range.
The problem then, is that the datarate is so low that a lot of that preserved dynamic range is lost in the compression to h.264.
This is one of the reasons I bang on about getting the HDMI to function in record mode of the K-01, so that dynamic range could be preserved for much much much better final presentation after colour grading.
Recording in 'Raw', or Compressed CinemaDNG, would also preserve that data - frankly, with Raw recording, IMHO, the K-01 would kick the butt of some very expensive competitors. There were some very smart choices made in some areas of the Pentax video engineering, that are hobbled by some very silly choices in the firmware.
This line,..
Originally posted by PiDicus Rex Yup, that's ND filter territory.
..., Was referring to the description of how bright the conditions were, and how use of ND's would allow a lower ISO and lower Shutter Speed.
In the described conditions, I'm suprised at the use off 400ISO over 100 or 200, though coupled with the high shutter speed, it would be understandable when shooting sports videos.
Originally posted by LensBeginner What's a "flacky", I googled but didn't find anything.
That's because I spelt 'Flecky' wrong.
Short for Reflector,...
Collapsible Reflectors | B&H Photo Video
