Wish I had a good camera for video. I’ve been holding out in the hope that Pentax would deliver a good camera for video
If people mentioned that it looks washed out it’s most likely because of the
black point. This shadows on the surfer are not dark enough to reach a rich black. Try adjusting the black point to the point at which the shadows become, “true black” and see if you think it’s an improvement.
I’m not sure what software you are using, most programs will have a contrast adjustment but that might possibly blow out your highlights more than you want to and your highlights are fine the way they are.
Of course the grading is a lot to personal preference; though usually film is graded so that pitch black appears in some of the shadowed areas and on black objects.
The only thing that really stands out to me as needing attention is the opening font in the beginning of the clip , “
4 Waves”. They just blink out, while the video in the background is in the process of an adorage, (also known as a crossfade)!
If your footage is already using a lot of crossfades you probably want to lean to your text using crossfades already and especially if the footage is in the process of a crossfade, otherwise it can look unprofessional and be jarring.
Ideally the text should be
linked to the clip that is fading out so both the clip and the text fade out at the same time as the new clip comes into presence.
Nice footage. Hoping the full frame will have good video, if not then it’s a Samsung nx1!
