Originally posted by clackers According to you, that shouldn't be necessary.
You can't have your DPR cake and eat it, too.
Move on, stop trolling.
I've never said Sony provided all features to all cameras. I can give you examples of cameras from Sony and Olympus and Fuji etc who have all provided additional functions via their free firmware updates. I can't do that with Pentax, as it hasn't happened in a long time. I believe focus peaking came to the K-01 perhaps, no that little one, the original Q?
In seven versions of K-3 firmware there are 2 "Added" references, no 3 if you include an automatic power off when the camera detects it's having a mirror seizure:
- Added Bracket shooting in [Anti-Aliasing Filter Simulator]
- Added Diffraction Correction on Lens Correction
- Added automatic reset function when detecting rarely occur abnormal motion of the sequence (- Personally I'd have rather a solution for the root problem, rather than a pull the power out if it happens 'fix')
Latest K-3 Firmware Update : Software Downloads | RICOH IMAGING
Sony and Olympus each offer high bit rate video options. The A7ii offers the XAVC S codec. I'm sorry if your original A7 doesn't. I feel for you because no camera from Pentax offers anything close either, so we've got that in common.
Sony and Olympus now each have a camera/cameras with sensor stabilisation during video recording. They also do some cool interactions with lenses that have OS onboard, so you can get the best from each setup.
Pentax doesn't.
That's the point of this thread, how does one gets lens stabilisation working.
Steve and others have answered this by explaining that only earlier model Sigma lenses have real OS built into the lens, in Pentax mount.
To use it (if you are lucky enough to find one with OS built in) you have to hold the shutter button down in a half press to enable the in lens stabilisation.
Originally posted by archetwist Hello, as we know, in the video mode K-3 uses electronic, and not mechanical stabilization. I have also read that for some reason the in-lens stabilization (present in some of the Sigma lenses, for example) does not work. Can anyone confirm whether the in-lens stabilization works in the K-3's video mode?
Hi Archetwist, I hope the above has answered your initial questions?
Welcome to the forum, glad to have you onboard
