Originally posted by Steve.Ledger Filters are applied to JPEG, not RAW.
Erm... the filters only work when the output is JPEG, and not RAW. That totally makes sense, because RAW is supposed to be the original data from the sensor (though it isn't completely, but close at least). Applying any effects onto that RAW file doesn't make any sense.
The question is if the camera processes the RAW file, compresses it to JPEG, then reads that JPEG, applies the filter and saves it again. In that case you wouldn't be able to do much with the file anymore. However what if the filter is applied earlier in the chain (which seems more likely). Perhaps even before the camera converts the data into an 8 bit image. I think it is quite possible that they do the shadow recovery for example to the 14 bit RAW data, and after that convert it to 8 bit and save it.
