Originally posted by PiDicus Rex I haven't seen any audio bar graphs on any of the Pentax's I've used.
Which, yes, also includes the possibility of them being there and me not having found them.
I think Mjpeg should actually be Easier to process then the h.264 - for starters, it's Intra and not Inter frame compression, so there's none of the Long-GOP and prediction math to worry about, only the Discrete Cosine Transform applied to each frame individually.
Frankly, I wouldn't be suprised if the FPGU's in most cameras could do Intra frame compression using Wavelet math instead of the DCT math.
HDMI may be hardware limited, but I doubt it. There's no good reason for the OEM supplier to make a chip that won't do all of the frame sizes and rates of a particular HDMI standard.
No, what I think the problem is, is that the HD signal is down converted for the live view, and it's that signal which is then fed to the HDMI chip, which locks to the incoming frame size and rate and outputs in the same format.
The Sensor's vision should be sent to the HDMI parallel to the processing that feeds the live-view LCD.
And yes, SR, just switch it back on.
I thought I read somewhere, in an interview with Nikon or so, that they couldn't do HDMI on certain cameras due to hardware limitations. But that could be my poor memory misguiding me...
I also thought I saw audio meters, which are useful with manual gain control, at least on some of their cameras like the K-1. But again, I can't say that for a fact. I thought that's how you adjust manual gain on the cameras without headphone, or when you haven't plugged in a headphone.
Btw, the AGC in the Pentax K-5 is beyond terrible. It doesn't just normalize everything... it makes the louder passages softer than quiet ones! As in, there is a 6-8 db difference between loud passages and soft passages. It also adjusts very fast.
@gbeaton: I think it depends on what you consider good video quality. The iPhone 6 is not bad... just watch Tangerine, which was shot on a couple of iPhone 5s. But there are certainly advantages to shooting with a DSLR or similar. If you want everything in focus, and sharp as a razor blade, then the iPhone is your weapon of choice. If you want to have control over what is in focus, and a more "cinematic" look, a DSLR will be better. Dynamic range is also something that DSLR can be better at.
