Originally posted by andher76 In any case, here a screenschot of the footage with the muted profile that I made with the Pentax K3. What do you think, how can I improve it talking about high/low keys and loss of details?
That looks like a pretty good starting point - some of the trees to the left side look overexposed, given there's not a large percentage of subject matter that's completely shadowed in to the blacks, I probably would have set the camera to expose a little darker overall.
I'd lay odds on, when you get that footage in to your NLE, there'll still be detail in those overexposed areas.
It might not be accesable if you're using Adobe software, in Edius or Resolve, you definitely be able to pull the highlights back a bit.
Originally posted by andher76 My question is, at this point, what is the BEST setting for High/Low keys in order to loss the less info is possible.
There is no 'best'.
What the High/Low key does, is stretch the image, to either give more detail in shadows at the expense of the highlights, or more detail in the highlights, at the expense of the shadows.
It's similar to the "Knee" setting in an ENG News or Studio camera.
When adjusting it, where it looks right to your eye, and matches the way you want the footage to look, is where it is 'right'
Just like in Stills, everything about your image is subjective, and once you have the technical aspects sorted, everything else is dependent on what you like.
---------- Post added 28-06-17 at 06:38 AM ----------
Originally posted by richandfleur Just remember a LUT is a starting point, often developed for other cameras, and is just part of of the overall grading process.
Spot On!
---------- Post added 28-06-17 at 06:42 AM ----------
Originally posted by andher76 My question in fact is, how can I set H/L keys in order to get the most details is possible in both dark and light areas. Should I move the low keys cursos until I get the maximum on the left of the histogram and move the High to get the same on the right (before burning of course)? And what about the risk to loss some details? I ask this because it seems, looking i.e. at Sony S-logs (or everything coming out from an Arri) that the flatest the image in H/L keys the best it is...
See comment earlier in this reply, but to reiterate, High/Low Key stretches one way or the other, it won't improve both Shadows and Highlights, you either get more range in shadows and less in highlight, or, you get more range in highlights and less in shadows.
Adjust it when looking at a scene to preserve detail in that area that is most important to the scene.
An example of how I use it,.. is that I will first set my exposure, say, I'm outdoors, the sun is bright, and I set the exposure so part of my background is not overexposed, but that means my foreground is in the shadows, I can then shift the high/low key to stretch out the shadows in to the mids, and squeeze some of the highlight closer together.
It's also one of the last final tweaks, to get that last little bit of image character right, after doing things like setting up shades and reflectors.
