Originally posted by clackers Can you hear good audio coming through, Nighthawk?
If not, you can line up the audio waves and align them on a known visual cue ... you'd only have to do this once for each file.
Yes, that is how I am currently editing. It is tedious!
---------- Post added 05-23-2018 at 01:25 PM ----------
Originally posted by richandfleur Is the audio issue that it doesn’t sync with its own K-7 video, or is it that it’s running faster/slower than the other camera video files you have from the same day, or something else?
Audio is fine. I believe it has to do with either the timecode format, or metadata.
---------- Post added 05-23-2018 at 01:27 PM ----------
Originally posted by PiDicus Rex On top of what's said above,.... how old is your version or Prem Pro?
Premiere was notorious for sync drift over long sections of video, for many years and many versions of the software.
I'd expect there to be a difference in the frame rate of the cameras, but if they're all identical, I wouldn't expect the audio to drift within the camera.
It is Premiere Pro CC v12.01, build 69 -- the latest as far as I know.
All footage, all cameras are720p, 30fps.
