Originally posted by o!d To avoid the flickering you need to shoot at a framerate that is divisible by the Hertz of your electricity supply, i.e. 25fps in eu and austrailia, 30fps in america.
Without full manual control I'm not sure theres anything you can do about it really.
Not exactly true.
With a shutter speed of 1/30s, the flickering due to 50Hz (or 70Hz LCD flicker) is already rather tolerable (and invisible with 60Hz). Of course, a shutter speed of 1/25s or 1/50s would be perfect for 50Hz but this cannot be enforced. btw, framerate is irrelevant, shutter speed is. Everything which 25fps at 50Hz gives you are
stationary dark bands
In order to enforce 1/30s shutter speed, switch to manual aperture control and try using smaller apertures (higher f-stops) until the flicker is gone. If necessary, combine with +EV exposure compensation. It is not true that only
full manual control allows you to control
something ...
