Originally posted by sledger Excellent Falk!
PENTAX K-7 AVI's are read and the info is shown in the 'Maker notes' tab of the ExifTool GUI
Originally posted by falconeye I tried to read'em out but the info is missing in K-7 files with initial firmware (didn't try again yet).
You let me check again and yes, the Maker notes are now filled with plenty if information. Good we have talked about it again
Originally posted by netrex This is about the K-x.
Anyone got any idea which value shows the ISO used when recording?
And can the K-x use higher than 1600 when recording video?
Hi netrex,
to be able to read out any EXIF data out of recorded Pentax AVI is a world's first! You watched it live.
Now, what does this data mean?
E.g., one night shot of mine says ISO1600 and 1/13s. I doubt that it really can record at 1/13s with 30fps.
So, the AEXXX info seems to record the "advice" given by the metering system to the video controller. Also, in a video w/o AE-L, which part of the video metering is meant?
I fear that the video maker otes need a bit of research before we can really make use of it. I suspect that the "adviced" AEXXX values are mapped to some fixed ranges used by the video controller.
AFAIK, the (Auto-)ISO setting has NO influence on the actual recording and I believe to have found that the camera's unextended ISO range is always used.
