Originally posted by dom777 The Image seems to stop harsh and then move back a bit. Is this a normal behaviour or do I have to send it to the service?
This is normal and if you think about it, is unavoidable.
With start of panning, you will force the sensor to one edge, effectively restricting its degrees of freedom from 2 to 1. This must be so because the SR will try to compensate the start of panning action. As it cannot know the difference between start of panning and shake.
Now, at end of panning, the sensor will still sit at this edge. Fortunately, the SR algorithm has a low frequency term built in which causes the sensor to always crawl into the middle to have max. degrees of freedom for the next shake.
What you would need is a pan button but there isn't any ...
