12-28-2009, 10:53 AM   #1
Kx (or K7) Controlling shutter speed?
What techniques are there for holding the shutter speed constant at, say, 1/60th, if the lighting conditions are changeable? Thanks.
12-28-2009, 11:37 AM   #2
You can always use Tv. It will keep the shutter speed where you put it. It will change aperture and ISO if your camera is set on Auto ISO.
12-28-2009, 11:47 AM   #3
Banned
QuoteOriginally posted by flyer Quote
In video mode ?
12-28-2009, 11:52 AM   #4
Yep - sorry if I wasn't clear - I'm meaning while in video mode.
12-28-2009, 02:58 PM   #5
netrex's Avatar
How will this be possible on the K-x where you have to choose the video camera icon on the mode dial (where Tv is also).
12-28-2009, 03:14 PM   #6
Eruditass's Avatar
You can't, unfortunately, you only get Av mode.
Only thing you can do is lock exposure once you get a shutter speed you like.
12-28-2009, 04:41 PM   #7
Banned
QuoteOriginally posted by Eruditass Quote
How do you know what the shutter speed is in video mode ?
12-28-2009, 04:55 PM   #8
QuoteOriginally posted by jogiba Quote
In video mode ?
It's nice of you to wake me up after such a stupid answer.
I guess I need to catch up on sleep.
12-28-2009, 05:03 PM   #9
So you can lock exposure? That's good to know - the DP review that just came out seemed to imply that you could only lock aperture, and that gain and shutterspeed would continue to fluctuate.
12-28-2009, 06:42 PM   #10
Banned
AE-L fix on the KX:
[yt]http://www.youtube.com/watch?v=68AQzJE1tdI[/yt]
12-28-2009, 10:02 PM   #11
Thanks for that - no mention of AE-L whatsoever in the video section of DPReview, and dire warnings about exposure changing during shots, so they apparently missed that feature.
But ... any way to determine what shutter speed the camera is being locked to with AE-L?
12-29-2009, 01:21 AM   #12
netrex's Avatar
I hope they fix manual control. Filming with the wrong shutterspeed with certain lights make everything flicker and look really bad, so it will pretty much be useless in those cases unless you're lucky and get the right shutter speed by chance.
12-29-2009, 04:54 AM   #13
falconeye's Avatar
QuoteOriginally posted by Coby Quote
Back in June, I compiled a chart for the K-7:
Falk Lumo: K-7 as a movie camera -- PART II: Controlling video recording
The K-x should be similiar (except that with 24fps, it should target less than 1/30s -- also, I assume that K-x won't use extended ISO even when enabled and I am not sure if it would use ISO 6400 -- do your own tests and report back). The chart was compiled by observing that the same exposure (in EV terms) is used in video and still LV mode and by observing where the video controls started blinking red.
12-29-2009, 10:42 AM   #14
Falk, Thank you very much for that link - that chart is exactly what I was hoping might be available. It's encouraging that there is a fairly wide EV range where the K7 maintains a sensible (low) shutter speed - and that it will respond well to ND filters. Some of the K7/Kx footage I've seen online uses way too high a speed in bright light and looks bad.
I bit the bullet last night and ordered a Kx, and will attempt an equivalent EV chart for that camera ....
12-29-2009, 11:01 AM   #15
falconeye's Avatar
Great, I'll link back to your work then.
If you feel tempted to measure the exact exposure time (I only estimated it) then it is easiest to film a flickering source, pan horizontally and count ghost images looking at a single frame. Some high end audio devices have nice flickering display Some power "LEDs" do flicker, too. Use blurred still photos (no SR) to gauge.
hdslr, shutter, video
Shutter speed on K-x CrabShadow Troubleshooting and Beginner Help 7 08-14-2010 06:46 AM
what shutter speed did i use? pete_pf Pentax SLR Lens Discussion 9 10-20-2009 01:45 PM
Shutter Speed comovartia Pentax DSLR Discussion 3 12-20-2008 10:38 AM
Shutter speed?! seymop Pentax DSLR Discussion 4 10-02-2007 07:28 PM
Shutter Speed? ryanmkk Pentax DSLR Discussion 4 11-15-2006 03:27 AM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
