Originally posted by adelena No, MJPEG is certainly not a container format but AVI is (per the article you linked to by the way.) In the Kx's case it contains MJPEG. There are innumerable formats that come as Quicktimes.
i see your point about the kx avi container format, with an mjpeg codec file inside of it... transcoding would still totally change the file, even if the output was to avi again.
Originally posted by adelena I did not mean to suggest that changing the wrapper or file format would leave the essence intact or untouched but that sometimes, in the real world, we have to make hard choices about "preserving levels of brightness" or moving to a format that is easily editable.
the "level of brightness" was a serious problem with quicktime only, to the best of my knowledge, it was never a problem with the avi container, or any other container format that i know of:
"As we see the problem at the moment:
- 5D Mark II writes signal in QuickTime H.264 MOV-file in its full quality.
- Apple QuickTime Player can adequately display these MOV-files.
- But most NLE,s (Edius, Vegas, Premiere, After Affects, ...) perceive these MOV-files in a distorted form (see attached image):
--- Shadows and Highlights is lost (red zone);
--- The subtle gradations is lost (gaps in the histogram).
It is pretty much a known problem 'quicktime gamma shift' (search Google). For example: DV - Columns - Brighter Whites; Richer Colors, Part 1
Either we are waiting for improvements in the NLE. Or need a utility that correctly converts MOV-files in a format suitable for NLE."
Problem with Canon 5D Mk. II video? at DVinfo.net
since we are still photographers who understand histograms, we know how serious of an issue that was... basically, you couldn't bring quicktime files into a pc editing environment... i think that apple finally fixed that huge bug in a recent and totally unheralded quicktime update.
cr*p like that is why i don't ever use quicktime or the mac platform, but if you are using it, you should be just fine with transcoding to the prores intermediate codec before editing... with imovie, i believe that you don't get prores, you'd have to use aic instead, which is decidedly inferior to prores... on the pc, i used to use the canopus intermediate codec with avchd, before i stepped up to the overclocked i7 920 cpu.
