02-13-2010, 02:51 PM   #1
full manual control with fader ND?
wouldn' it be possible to have full manual control using manual lenses together with a fader ND?
Light Craft Workshop - Fader ND adjustable ND filter (ND2~400)
you could set aperture at the lens, fast and easy find and lock right shutter and ISO and then adjust exposure later just by using the fader ND again.
The smallest 52mm fader ND goes for around 50$ new, my M-lenses are 49mm so a regular step-up ring would do the job. Except for low-light environments (fader ND starting at ND2), this should give full manual control or am I thinking wrong here?
Phillip Bloom rates the fader ND almost as good as the 350$ Vari ND when he shot with both of them in India.
I'm talking K-x right now, I don't know if shutter can be locked on K-7 with the work-around known for K-x...
02-15-2010, 06:54 AM   #2
jaitas's Avatar
I haven't tried that yet withvideo on my K-7 but i have the mentioned 52mm fader ND. And I have found it very good product for the price. I use it mainly for FA 50mm f1.4 and DA35 macro lenses.
Have to try that with video too. But I think it should work
02-16-2010, 08:02 AM   #3
QuoteOriginally posted by karl79 Quote
What do you mean by "full manual control" ? Can you give example?
With using a manual lens, I think I already have nearly manual control.
check my video please.
[YT]http://www.youtube.com/watch?v=vAWvrNv0MEo[/YT]
02-16-2010, 10:53 AM   #4
With full manual control I mean control over aperture, shutter speed and ISO at the same time.
K-x gives you aperture control but defines the other 2 settings automatically in video mode.
The workarounds some guys pointed out here to lock shutter with manual lens works for me.
Still it can be a pain finding a 1/50 shutter depending on the environment your in and you still can't always set ISO as you want without often having to change aperture then.
My thought was that the fader ND could replace any in-camera exposure compensation (or having to change desired aperture) as it goes from ND2 to ND400 (1 to 8 stops). You could choose the exact ISO value you want, choose aperture you want, aim at your subject, tweak the fader ND until you have 1/50 shutter, lock it, switch to video-mode and adjust exposure to the right amount again just by using the fader ND, so without changing any of the settings you've chosen.
Finding and locking settings should be much easier and faster.
Doesn't work for low-light environment of course as it starts at ND2 but wouldn't this work for any daytime / outdoor / proper lighted scenes?
Just would like to know if I'm thinking wrong before purchasing one
jaitas, have you tried already?
control, fader, hdslr, shutter, video
K5...manual video control? D4rknezz Pentax DSLR Discussion 23 09-30-2011 06:46 PM
Pentax K2000 No Manual Control pearsonbe Pentax DSLR Discussion 6 02-01-2011 11:54 AM
Won't touch the K5 without 24p and manual control eccentricphotography Pentax DSLR Discussion 55 09-27-2010 07:25 AM
Canon EOS 550D with full manual control and 1080p 30 FPS. Firmware update time now? netrex Video and Pentax HDSLRs 17 02-10-2010 12:13 PM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
