Originally posted by C_Jones just to make sure that the HDMI output your camera provides will be accepted by the device.
Most field monitors support at minimum HDMI 1.4 and should work fine from that perspective for the K-1. Output HDMI resolution for Pentax cameras is the same as for the rear display and display resolution (pixel dimensions) is negotiated between the display and source device. What works for the Panasonic will work for the K-1.
Originally posted by C_Jones The Pentax K-1 HDMI output terminal socket is HDMI Type D
Cables with Type D male are readily available and are not an item to scrimp on. That said, I had nothing but trouble connecting my K-3 to an external display despite cables from a reputable maker. Short story is the cables were defective. If connecting does not work, cabling might be the culprit.
