Originally posted by rustynail925 Anyone here has the Panasonic Lumix Lx3 ?
I have two Pentax compact cameras: the LX3 and an FZ35. You can read about my reasons for buying them and my experience using them, here:
Traveling light: The post-mortem William Porter Photography Quote: Ive been thinking of getting one since there are some occasions where you dont wanna be carrying a dslr with you.
Right. I have a camera with me just about everywhere I go. That camera is now, more often than not, an LX3.
Quote: Got a few questions:
If base on the 1.5 crop factor like the Pentax whats the focal length of the LX3?
Sorry, I'm not sure I understand the question. If you are asking, does the LX3 have the same sized sensor (and thus the same crop-factor) as the Pentax DSLRs, the answer is an emphatic NO. The LX3 is a compact camera with a much smaller sensor. I can never remember the precise crop factor. Let's see. Wide-open—which is where I keep it 90% of the time—the camera's aperture is reported by Lightroom 3 to be 5.1mm. And that is supposedly equivalent to 24mm on a full-frame camera. So the crop factor = 24/5.1 = roughly 4.7x. As I said the sensor is MUCH smaller than the sensors in any DSLR.
Quote: At its price point is it the best point and shoot right now?
Forgive me, but I'm not sure the question is meaningful. "Best point and shoot"? For what purpose? Underwater shooting? No, because the LX3 isn't waterproof. Shooting wildlife? No, because the LX3's zoom only goes to 60mm effective (= the Pentax 40mm APS-C lens in angle of view). Most compact pocket camera? Not really, because the LX3 has a lens that sticks out in front all the time. Best for low-light shooting? Definitely not, as the LX3 struggles when it goes much over ISO 400.
Still, the LX3 is a great compact camera, for what it does best. Best description of it: It's a great lens (Leica) attached to a very small, and very capable body. The body gives you just about the same degree of control you'd have over a Pentax DSLR, including being able to shoot raw, have full manual control over just about everything. And in addition, it shoots really good movies, has a bunch of special effects built in, and more. The body is very attractive. The controls are intelligently laid out. And if the light is good, the pictures are awesome.
I think an LX5 has been announced and should be out soon. Some minor improvements including a slightly longer zoom range. Samsung and Canon also have cameras designed to appeal to the same class of users as the LX3—serious enthusiasts. I looked at everything and picked the LX3 and I'm happy with the choice.
Quote: Does it enable you to select focus just like a dslr?
Absolutely, but be aware: manual focusing on just about any fixed-lens camera involves moving a slider, rather than turning the lens barrel, and this makes it a bit more awkward. Plus, you're watching the focus on an electronic display screen rather than through an optical viewfinder. It's doable and I suppose if I did more of it I'd get better. But most of the time I'm using autofocus.
Quote: any comments on the Lx3s handling, IQ, Noise, etc?
Handling, in my opinion, is generally terrific, for what the camera is. Image quality is better. Under optimal conditions, it can take photos technically as good as those I take with my K20D and a good lens, or very nearly so. The problem is, if the lighting conditions are even slightly less than optimal, the LX3 will be impacted more than a DSLR. Noise, as I said, is a problem. Many experienced LX3 users that I talked to say they set the camera so it won't exceed ISO 200. I've set it to ISO 400 max, although I have exceeded that occasionally.
One thing to note that's really special: At 24mm-e (i.e. wide open) the LX3 has a max aperture of f/2.0, which is really impressive for a point and shoot camera and also gives you a 1-2 stop advantage over most other point and shoots. This helps keep the ISO down.
Three other nifty things to mention about the LX3. These may not be unique, but they are things I value about the LX3.
First, you can switch aspect ratios while shooting. The camera is designed so it doesn't just crop the photos, rather, gets the max pixels into all four aspect ratios: 4:3, 3:2, 16:9 and 1:1.
Second, there's a macro focusing mode for very close focusing.
Third, the iA (intelligent auto) shooting mode does a fantastic shot with difficult exposures. Unfortunately you can't shoot in raw in iA, apparently because of what the camera does to boost shadows and control blown highlights. But I've actually started to shoot jpeg only when using the LX3. Controlling the shutter and aperture is a bit awkward, so I tend now, with the LX3, to put it into P or iA and worry mainly about exposure compensation and composure.
Final point. The LX3 hasn't turned out to be quite as capable as I hoped it would be. I'm not disappointed. I think my original expectations were a unrealistic. If you accept that it's a compact camera with a teeny sensor, and that it can't really compete with a DSLR, then you may be very happy with it. It's certainly the best compact camera I've used.
Will
