12-20-2010, 07:53 PM   #1
Welsh Dog's Avatar
Overseas battery charging.
For various reasons I bought a Panasonic FX40 the other day but am yet to charge it (it's a Xmas pressie).
However whilst I bought it from B&H in the US, I'm in Australia. The US runs on 110v... we use 240v. Admittedly I should have considered this before buying it but there ya go.
Will there be a problem charging the battery or can I just use a plug converter and carry on as normal??
12-20-2010, 08:03 PM   #2
My Pentax charger accepts 100-240V 50/60Hz, it says so on it's bottom among lots of other small print. I suspect yours is similar, check it out. If the voltage is ok, then a plug adapter will do it. Also, if the mains lead is the kind that plugs in the charger you can probably find a replacement that fits your sockets directly.
battery
Another battery charging option WheresWaldo Pentax Camera and Field Accessories 1 07-01-2009 08:56 AM
Need adapter for charging battery in UK Green_Manelishi Pentax Camera and Field Accessories 2 03-05-2009 04:28 PM
Battery Charging the K10D on the road GRIZZLY GULCH Pentax DSLR Discussion 4 02-27-2008 04:25 PM
Charging the K10D Battery Kemal Photographic Technique 2 03-12-2007 07:15 AM
Power inverter/battery charging PeterAM Pentax Camera and Field Accessories 3 12-14-2006 12:32 PM
All times are GMT -7. The time now is 03:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
