I'm not familiar with DPR's report on metering inaccuracy on the D7000.
The two-stop underexposure is my experience with an f/1.4 lens (Super-Tak). But many other people report a similar "curve," e.g. it's wildly under-exposed at very wide apertures, is pretty correct from f/4 to f/5.6, then gets over-exposed as you stop down further.
https://www.pentaxforums.com/forums/pentax-dslr-discussion/25931-k10d-my-old-...tml#post228108 My experience is similar for all non-A lenses. For large apertures (under f/5.6), I get underexposure (about 2 stops at f/2). For smaller apertures, (over f/11), I get overexposure (about 1 stop at f/22). http://photo.net/pentax-camera-forum/00Krj8 The K10D's green-button stop down metering mode above will tend to overexpose a bit unless the lens is at wide open aperture. If you're shooting at f/5.6 or f/8 with an f/2 lens, cutting exposure time by a factor of two stops (ie: 1/100 sec becomes 1/400 sec) will usually get you closer to the right exposure. http://forums.dpreview.com/forums/read.asp?forum=1036&message=34242004 Stop-down metering in M mode + Green button with manual lenses is just as poor as with the previous models I've used: K20D, K10D and *ist DS. The error increases as the aperture decreases.
and again, on this very forum (check Lowell's graph.. it shows the same curve that I report). Another poster does report that the K-x is more accurate (only 1 stop under-exposed at f/1.4, roughly correct from f/2 to f/11, over-exposed one stop at f/16).
https://www.pentaxforums.com/forums/pentax-dslr-discussion/86746-accuracy-k-x...42-lenses.html https://www.pentaxforums.com/forums/pentax-dslr-discussion/90344-green-button...nual-lens.html https://www.pentaxforums.com/forums/pentax-dslr-discussion/39189-metering-man...asperated.html
The reason why Pentax metering with old lenses is dodgy, is because they removed the aperture-sensing prong from the body. Look at any old Pentax film camera and you'll find that prong, which physically senses the position of the aperture ring. That's why all Pentax DSLR's have a
crippled KAF mount.
http://kmp.bdimitrov.de/technology/K-mount/crippled_AF.html
My point was, the D7000 does have that prong, and is the first consumer Nikon body to have it (the D1/2/3/700/200/300 all have that prong). No Pentax DSLR has ever had that prong. Which reduces Pentax's claims of compatibility with old lenses.
Now getting back to the fact that Pentax metering is well-documented to be dodgy. As I said, at f/1.4 you press the green button, then decrease the shutter speed by 2 stops. Or 1 stop at f/2.8 (and so on). It can be worked around. But it's damn annoying. In-camera metering is not supposed to require compensation every time you take a reading.
Now as for the actual metering performance of the D7000, I won't try to guess since I have no interest in Nikon anyway.
I however applaud their effort to maintain compatibility with old, old lenses by putting that prong on the D7000. I don't understand why el-cheapo old Pentax SLR's had that aperture-sensing prong and then Pentax took it off (back in the film era, even the MZ-50 didn't have it anymore, but the MZ-5 had it and of course the MZ-S).
I would gladly pay $100 more for a DSLR that had that prong, but apparently even on Pentax's top-end digital body they can't be bothered to restore that feature.
