i've contemplated between the K5 and the D7000 and last month, i decided to get the D7000.
After using it for a month, here's what i've found to like and dislike. I'll limit it to what i deem are the more important features.
The AF is fast, accurate and consistent. It's not perfect, but what i've found is that it's predictable and consistent.
AF is quite configurable between 9pt, 21pt, 39pt dynamic and 3D. Haven't used the dynamic yet, but the 3D works great, but as noted by Nikon, it can be fooled.
The Flash is excellent. Exposure is very accurate and consistent. It's not easily fooled by reflective objects. This is one aspect of my pentax bodies (dl, k10, km, kx, k200) that i find to be very inconsistent.
Shutter noise is quiet, not as noisy as the Kx, but not as quiet as the k7/k5.
Body size is good (for me). I don't find the body bulky at all. The k7/k5 kind of "feels" nicer when held though. however, the kx/km was a tad too small for me.
Battery lasts quite a bit on a single charge. (Doesn't use AA's though
Switching between AF modes (AFA, AFS, AFC and Single, Auto, 3D, 9pt/21pt/39pt dynamic) by pressing a button and turning the control wheels is very convenient.
Configurable MyMenu - add most commonly used items to this menu. Very nice feature.
In-Lens VR/VC. this also stabilizes the image on the VF which in some instances can help with AF. The first time i used the Tamron 70-300 and the VC kicked in, it was amazing. I was asking myself, can i really hold this thing this steady at 300? switching the VC off told me my answer. No.
Dislikes:
Switching between AutoISO and manual is a PITA to do thru menus. This is 2 or 3 button press in the Pentax. To aid in this, i put this menu item in MyMenu to save a few button presses:
Edit: programming the fn button and adding the AutoISO On/Off to the top level of MyMenu is effective in toggling AutoISO On/Off so this is no longer a dislike
When the camera can't accurately meter i.e., beyond its specified range, (in Av Mode), the shutter speed displayed is "Lo". Why not just display the shutter and flash it? "Lo" does NO good at all.
There's no instant 100% zoom when reviewing the shot taken. this is programmable in the pentax.
No pixel mapping. This would be a nice feature to have.
In-Body SR will work with any lens mounted. If the lens doesn't have VR/VC/OS, you'll need your skill to steady your shot.
Other thoughts:
I thought i'd miss the AA batteries of the Kx, but i can still use that with a grip on the d7000, and the LiIon battery lasts quite a while.
As a system, there's quite a bit more support both from Nikon and 3rd party vendors.
Lens support e.g. Tamron 70-300, 18-270 pzd and 60mm. Yes, the nikon lenses are pricier and the higher-end lenses are stratospheric, but at least they're available.
As many folks have stated, buy the camera and system that works for you.
So far after a month, I like the D7000 and the Nikon system. There are a few quirks and annoyances, but it is with ANY system and so far, i haven't found any to be a show-stopper. What will be my primary category for judging is the number of keepers and so far, my keeper rate has gone up.
The primary lenses i use is the 16-85 and the tamron 70-300 vc.
here's a few shots taken with both lenses:
Zenfolio | Jordan Paw Image Arts | Nikon
BR,
jordan
