Originally posted by nickthetasmaniac It does if you get the right native lenses. A G3 for instance with the Lumix 14/f2.5, Lumix 20/f1.7 and m.Zuiko 45/f1.8 is an insanely compact, fast and high-quality three-prime kit that simply cannot be replicated with a dSLR.
But yes, if you're adapting (especially dSLR lenses) that advantage rapidly disappears as you just can't avoid how far the lens mount needs to be from the sensor...
Nick - but you are bumping up against the same issues I mentioned above with the 5N.
G3 : 115 mm x 84 mm x 47 mm (4.54 x 3.29 x 1.84 in) and Approx. 544 g (19.2 oz) inc. battery.
Lenses : Lumix 14/f2.5 (insanely light - 55g), Lumix 20/f1.7 (100g) and m.Zuiko 45/f1.8 (116g).
vs
Kr : 125mm x 97mm x 68mm (4.8 x 3.6 x 2.7 in). With D-LI109 battery: 598g (20.5 oz).
Lenses : 21/3.2 (5.5 oz./155g) with hood, 35/2.4 (124g/4.4 oz.), 40/2.8 3.2 oz. (90g),
So the G3 has a 1cm x 1cm x 2 cm & 50g saving over a Kr. The G3 with lenses give you savings of 154g / 78g / 80g over a Kr with primes.
What's the point of dropping the IQ and superb high ISO of Pentax primes and a Kr for that ?
