Originally posted by wolfiegirl Ok I need to ask... NIF adapter? What's that short for? Not In Focus?
Non-infinity focus. The wide-flange M42-PK adapters are NIF. They push the lens 1mm further away from the sensor. Bye-bye infinity. Hi there, intimacy. The effect can be minor for lenses 180mm and longer, or striking for glass shorter than 60mm. An NIF adapter is great for portraiture because we don't care about infinity.
Quote: Hrmm.. more 50s... I was hoping to get out of the fast fifites.. I've got like 6 or so of those now, all with different aperture speeds as well as a few doubles with different coatings. Still, if it lets me in super close perhaps it can push out the manuals.
Let's talk about close-focus distance (CFD). My SuperTak 50/1.4 and 55/1.8 each have a nominal CFD= 45cm. The cheap safe NIF adapter pushes that down to about 27cm. Many 28mm lenses have a nominal CFD= 30cm. On a NIF adapter, that drops to 15cm. Far focus on a 28 drops from infinity down to maybe 1m.
Quote: Just as important, did any of the three you just recommended require modding?
The Meyer|Pentacon and Porst are straight M42. The Porst has an A/M switch. The Meyer Orestron | Pentacon Color copies seen lack that switch; the aperture pin must be jammed down in order to work the iris. The CZJ Tessar is Exakta mount -- mod the adapter, not the lens. For close work, don't even bother modding the adapter. NOTE: the 12-iris-blade 1-ring-preset Tessar is one of my absolute favorite lenses, literally always in my bag, tiny and superb. And mine was cheap!
I know -- you'll ask, MOD THE ADAPTER? Like this: Take an Exakta mount lens. Glue an ultra-cheap M39-M42 ring around the bayonet. Grind down (on sandpaper) a cheap M42-PK adapter till the lens reaches infinity focus, if that is important to you. No cutting, no lens damage.
Originally posted by vonBaloney The 18-250 can be focused at a foot or so over its entire zoom range (which only gets to about 180mm when focused on close subjects). Very versatile.
Yes, it does go close. Its nominal CFD= 45cm but I measure it closer to 25cm. The DA18-55 also focuses closer than its nominal CFD of 25cm -- I measure it as under 15cm. Why are the specs so far off?
