Originally posted by northcoastgreg ....Even the slightest movement gets you out of optimal focus. For MF AF, I've always found OVFI a lot easier to work with, and have always been baffled that claim a magnified view in EV as a big advantage. For me, it just adds an extra step and makes it harder to compose the image.
Well, to each their own, I guess. Even with the K-3, my process for the majority of my (all field, all handheld) macro shots relied on magnified liveview. (One
sample at 2:1 here.) Of course, you do need to "pre-compose" the shot in your mind, decide where you want the eye(s) in the frame, and move your magnification zone to the area of the frame that will have the "must-be-in-focus-eye(s)". Then you slowly move the camera until you hit focus and trigger the shutter. That worked much better for me than trying to achieve focus using the OVF, but of course YMMV. Being able to move this process to the electronic viewfinder instead of using the camera's backscreen will help with stability of the camera body and better control of the movement required to hit focus, thanks to the third contact point provided by the viewfinder. That should result in a higher keeper rate than with the DSLR. That's the theory/hope anyway.
(Also, with some macro setups - using some manual, reversed, stacked or adapted lenses - the aperture is already closed before the shot is taken, and that can result in an OVF that is very dark since you are shooting flash and setting the aperture to expose properly once the flash fires.)
On the K-3, using the OVF
can work better than using liveview (for me) when shooting bursts for focus stacks because the liveview gets very choppy on a K-3 when shooting 8fps bursts, plus critical eye-focus will be achieved through the stacking, and slow and well controlled movement of the camera body is really essential. But I assume that the through-the-EVF burst shooting experience of something like a G9 (or a K-1 Mark II, or G95) is quite improved over the liveview experience of a K-3's 8.3fps bursts, and I hope not
too far off from what an OVF DSLR burst delivers...
I've still not actually bought anything yet. Hoping to contribute pictures to this thread rather than words eventually!
