Originally posted by Emacs Take a look at the Samyang 35/1.4 and Distagon 35/1.4
They are huge and still inferior optically to lux 35 asph fle
Old lenses… They are soft wide open. And SLR's ones are still large compared to pre-ASPH leica counterparts. And sharp from wide open ASPH glass is still smaller than old soft SLR counterparts up to 50mm. That's it.
if the samyang is the best example you can give, your argument is all but worthless. and the Zeiss is designed around the large throat of modern SLR mounts, just the same. even the m42 zeiss ZS lenses are huge, much larger than they need to be. I know, I have one. but that doesn't mean it can't be built smaller. the only drawback is the retrofocus design. an aspect I've already said can't be helped in terms of wide angle, but they can still be made much smaller, and be a better comparison to rangefinder lenses. it can be done, and the performance optically of old lenses is of little relevance. you aren't getting my point, clearly. both examples may be manual focus, to skirt the whole modernization aspect, but they weren't designed to be any smaller. especially the samyang. these two were designed on the same basic oversized base. zeiss lenses are just big, period. but if they wanted them smaller they could be, especially closer to the 50mm range. there, manual focus lenses of the same design principal, i.e. the 50's and 60's (which is where leica is still sitting in terms of overall lens design from a mechanical standpoint) are of little difference in overall size. I've owned a few leica lenses, so I know first hand.
its unfair to compare, because its like comparing design principals from very different eras, and the glass inside is irrelevant in this comparison. its about the overall size here. full frame SLR lenses can be made MUCH smaller. small enough to severely mitigate the often touted size difference between SLR and rangefinder lenses, and thats just fact, because a lot of them used to be that small.
