Originally posted by rawr Remember valid direct comparisons across systems with different pixel densities, AA filters etc aren't always possible.
The XPro1 sensor and that of the K-5 have the same physical size and the same resolution (16.3MP), so lenstip results are directly comparable. The AA filter removal was meant to improve sensor resolution, so why are you surprised that tests reflect that?
Originally posted by rawr If we went with simple resolution numbers from Lenstip or others, we'd be all using micro4/3 lenses...
Lenstip does not make any statement about the results being invalidated. They just say that the lack of the AA filter leads to better sharpness, which is what the removal of the AA filter was meant to produce.
As for "others", by which I assume you are referring to dxomark, they are scaling their resolution results to the sensor size specifically to allow comparisons cross-format. But then perhaps dxomark are morons as everyone was in agreement here before they published their K-5 test results.
