Originally posted by Buschmaster If someone "hacks" the lens, it would, worst case scenario, not focus correctly, right?
The best answer is: who really knows? An attacker could simply fry the lens for fun and turn it into an optical 'brick'.
But the lens has a chip, the chip has a CPU, the chip has an ability to store data in order to function, the lens has an ability to interface to the 'dock', the dock can interface with a PC, and then the world.
Since the existing chips in Sigma lenses already interface with the camera to tell the camera about focal length and aperture, perhaps the new lenses might also be able to query other data on the camera (GPS info, name of photog) or send instructions to the body. Maybe it could run scripts on the body or read or corrupt or maniplulate data stored in the body.
The mining bitcoins issue is a good iilustrative example. A program can be executed off-line, then dump data upstream (or talk to a command-and-control server to receive new instructions) once a network connection is detected. If over time there are millions of Sigma lenses out there, each with even modest or intermittent spare CPU cycles available, connected to millions of cameras and PC's, that's still a significant resource one could put to use in any number of ways.
When DSLR's get their own IP addresses, connections to Wifi and the web (it's already happening - eg the latest NEX's) not only the bodies themselves, but their whole accessory eco-system will need to be designed with security in mind.
