I recently purchased the D600 to replace my 5DII setup as I've been getting more into landscape photography and it's hard to beat the Sony sensors. Kind of feeling under the weather this morning so I decided to work on a little shootout. I also wanted to see how the K5 classic stacked up. This was a somewhat unscientific shootout, so take these with a grain of salt. The idea was to get a general idea though. But feel free to rip this apart
I shot them all with rough 50mm equivalents from a few feet away. All with same settings: ISO 100, f/5.6, 1/8 sec. from a tripod w/ timer. Auto WB & centerpoint AF. No noise reduction or sharpening in post.
5DII w/ EF 50mm 1.4
D600 w/ Nikkor 50 1.8G
K5 w/ DA 35mm Macro Ltd
First, uncropped shots. No uprezzing here...just to get a general idea. Stupidly, the 5DII shows up in the other shots. But like I said, this is more for generalities.
5DII:
D600:
K5: Something seems off w/ white balance/exposure here:
Then I did some some shots underexposing by two stops (raising the shutter speed to 1/30 on all cameras) then lifting the exposure by 2 stops in LR (no noise reduction). I then uprezzed the 5DII and K5 (resample using "best for enlargement" to the D600 res. and cropped 100%.
5DII:
D600:
K5:
A few thoughts. Unsurprisingly, much better background bokeh on the D600 and 5DII in the uncropped versions (they are FF after all and the 35Macro is not known for great bokeh at that distance). The bokeh is the best on the D600/50 1.8 I think. The white balance/underexposed issue doesn't work any favors for the K5, but if I spent the time to fix it in post I'm sure the image would look just fine. Overall, I think I like the D600 shot the most here.
Crops: As far as sharpness goes, the 5D wins here, oddly. I kind of wonder if the D600 may be just slightly OOF or perhaps the 50 1.8G needs to be stopped down a little more to reach a sweet spot. The 5DII is much noisier as that sensor lacks the DR of the other two cameras in this 2-stop exposure push. If I pushed this even further the 5DII would get worse. From my experience in the field, it doesn't take much for the 5DII files to start going to crap. The sharpness on the K5 is remarkably close to the D600 with a slight edge to the later (again making me wonder if the D600/ 50 1.8 needs a slight AF adjustment or something). Those extra 8MP should be doing something...the D600 is a little less noisy though.
To be honest though, all images deliver the goods. I'd say the law of diminishing returns is definitely present here, but the new Sony Exmors are definitely killing Canon in DR. And clearly and unsurprisingly, FFs deliver thiner depth of field.
At least as far as image quality goes, the K5 is a great value IMO at the current price point and sports a more robust body than the other two (D600 being the loser there, though the 5D is oddly cheapo in a few spots like the mode dial).
