Hello. On my Samsung 10.2mp SL420 compact digital there are optical and digital image stabilization settings.
I understand the difference as well as the minor and relative disadvantages of them at this level of camera. But I'm
unclear on when/where it might be appropriate to turn both/either one off (there is a setting that utilizes both at once).
If, as I've read, these settings introduce very minor degradation of the image quality (notwithstanding the major impact of motion blur when handheld)
would it be reasonable to leave them active in all circumstances except very controlled shots with a tripod? With no remote functionality, not even a cable attachment, for this camera I've simply set the timer for two seconds when using a tripod to eliminate movement.
Actually, I understand that OIS does not degrade the image. Shouldn't it always be active therefore? Why is there even an option for turning it off?
Thanks
