04-27-2014, 02:38 AM   #1
Unregistered User
Guest
Pentax lens on Sony a3000
Does anyone here use Sony a3000 with Pentax lenses adapted to it? Are you happy with the combination?
I am asking these questions because I am considering buying a body.
04-27-2014, 04:48 AM   #2
Otis Memorial Pentaxian
clackers's Avatar
I'm happy dabbling with them on a NEX 3 and NEX 7 ... same mount.
04-27-2014, 04:54 AM   #3
Hi, I am using a3000 with booster or tilt adapter.
Image quality is good. Very enjoyable combination
04-27-2014, 05:15 AM   #4
panoguy's Avatar
QuoteOriginally posted by VadikToronto Quote
Any chance you can post a photo from the combination? I'd be pretty interested as well... I was thinking of exactly this combo. (A3000, Lens Turbo, T/S lens)
04-27-2014, 06:35 AM   #5
A50F1.4 @ F4 on booster https://drive.google.com/file/d/0BwwJWYcCTVmmenc2bjJ1N2RHV2c/edit?usp=sharing
Kiron 28mm2.0 @F4 tilt down 8 https://drive.google.com/file/d/0BwwJWYcCTVmmbzFqWWNLYXppWEk/edit?usp=sharing
04-27-2014, 08:00 AM   #6
osv
a3000 sounds pretty cheap: Sony A3000 First Impressions Review: Digital Photography Review
maybe a used nex body instead? something with magnify capability, and a better evf... magnify/focus peaking is awesome for manual focusing.
the only speed booster that's worthwhile is the expensive one, which will cost you nearly as much as the camera body(??) the cheap ones are like shooting through the bottom of a coke bottle.
LensRentals.com - Metabones Magic?
you'll probably need wide glass, i'd spend the money on a quality e-mount aps-c lens instead... sigma 19mm/30mm, sony 10-18 zoom
04-27-2014, 08:01 AM   #7
I had a chance to play around with an A3000 at a not-so-local Walmart. It was plugged into power and worked just fine. I was always curious to know if the EVF had focus peaking and it does! The peaking is very dramatic too - much more than what I see on my K-30 with Live View. Everyone said how awful the EVF was and I will say that it's not great but plenty enough for composing, focusing, and shooting. The sensor rates a little lower in some cases than a K-30 according to DxOMark if you trust their scores. I have a feeling that at low ISO in bright light conditions with the same lens (adapted) you would be hard pressed to distinguish one sensor from another but that's just my guess.
04-27-2014, 08:17 AM   #8
panoguy's Avatar
Thanks for taking and sharing those! (This AM, here in the GTA no less...) Looks pretty good.
About the only thing that bums me out about APS-C is that my wide-ish tilt/shift lenses are normal or longer lenses on it, which makes landscape shots kinda tricky (try stitching multiple tilted shots together!). Using an E-mount camera that actually has a grip and EVF (and can be bought new for $300 right now) with a speedbooster or lens turbo adapter is a pretty good solution! Makes the FA lenses look good as well...
Thanks for asking the question, Dominic, and thanks for posting your photos, Vadik.
04-27-2014, 09:17 AM   #9
philbaum's Avatar
I bought the 5n first, then got tired of using the 5n in bright sunlight, got the nex 6 which came with built-in EVF. cheaper than buying an evf accessory and doesn't hang up on things going in the bag.
I've tried my pentax lenses out on the Nex cameras, including the DA 300, DA50-135, DA35 macro f2.8, then some macro Pentax lenses - M and A series. They all work in manual mode. Those pentax lenses with aperture rings let you know where you are at aperture wise, but you can use some of the adapters to adjust aperture as well on the auto AF Pentax lenses - but can't tell exactly which aperture your are at - if that makes sense. I have 2 fotodiox adapters.
As to purchasing a body, i'd put your funds primarily into the body to start with. focus peaking AND magnify tools for manual focusing are both necessary, as sometimes there isn't enough light or contrast for focus peaking to work by itself. And the built-in EVF is important on nice sunny days. I wouldn't be too concerned about buying used, mine have been very reliable and i always buy at the end of the marketing cycle for cameras when they are less pricey. I really enjoy macro lenses with the Nex cameras, more so than with DSLRs.
04-27-2014, 09:30 AM   #10
Banned
QuoteOriginally posted by osv Quote
Metabones does not make a focal reducer adapter for Pentax PK mpunt lenses to E mount cameras and the Lens Turbo PK-NEX adapter works fine on my NEX-3N.
SMC Pentax-M* 300mm F4 on NEX-3N :
04-27-2014, 10:27 AM   #11
osv
QuoteOriginally posted by jogiba Quote
good info, sorry to hear that there isn't a pentax version... but why would you only use pentax glass on a mirrorless? it would be silly to ignore the huge assortment of lenses out there... point is, even the metabones introduces some undesirable issues, and it's the best there is:
First Impressions: Metabones Speed Booster: Digital Photography Review
fwiw, a comparison of both:
"As can be seen, Lens Turbo yields an image with significant sharpness reduction. In my view, the image rendered by Lens Turbo is not a useable image.
Final analysis: Speed Booster is worth the extra cost of purchase."
Lens Turbo vs. Speed Booster
read the comment section... if you know who uhoh7 is:
"Uhoh7 • 11 months ago
I got the Nikon LT. So far, it's been disappointing. I have dramatic blurring at the edges from various Nikon lenses.
I'm afraid you cannot call The lens turbo Cheap because it's arguably unusable."
http://www.sonyalpharumors.com/more-lens-turbo-tests/
04-27-2014, 01:00 PM   #12
Banned
Why would I use my Pentax lenses on a Sony E mount camera ? Because I have 20 PK mount lenses and that is why there are many here purchasing APS-C and full frame E mount cameras to use with their PK mount lenses. I also have a 35mm F1.4 Bower Sony A mount , Sony 28-70mm OSS FE mount, Tokina 24-200mm full frame Nikon mount ,Sony 16-50mm E mount and Sony 55-210mm E mount lenses.
Here is my full frame VG900 with Sony 28-70mm FE OSS lens:
Here it is with PK mount 24mm F1.4 :
Here it is with full frame 24-200mm Nikon mount :
Here it is with Sony A mount 35mm F1.4 :
04-27-2014, 01:44 PM   #13
osv
hey, you know that i use my pentax lenses on the a7r but i also use a bunch of other glass on there as well... using any glass from any manufacturer is the whole reason that i went with e-mount.
crop sensor e-mount definitely has better bang for the buck, but if you want to use full-frame glass on aps-c, there will always be compromises... no free lunch.
btw, i just put up 24 drag racing pics that i shot with the pentax 28mm f/3.5... that lens rocks on the a7r, the sides are clean:
Drag racing photos
04-27-2014, 02:09 PM   #14
Banned
Drag racing photos
Nice shots, I plan on taking my GH4 next month to Englishtown for the NHRA Summernationals and shoot some 4K video and stills.
2014 Mello Yello Drag Racing Series Schedule
04-27-2014, 02:47 PM   #15
osv
lucky dog!!!
i shot at that track a couple of times, back in the '90's, the light is sooo good!
nothing in so cal compares, not even bakersfield or phoenix.
i've also been to atco, which is cool, but it's no e-town.
a3000, lens on sony, pentax, pentax lens, sony
Pentax 645 Lens on Canon/Sony FF 2351HD Pentax Medium Format 10 02-28-2014 01:44 PM
Sony A3000 tests up on DxOMark 6BQ5 Canon, Nikon, Sony, and Other Camera Brands 11 12-20-2013 06:53 AM
Sony A3000 - new 20MP sensor looks great yusuf Canon, Nikon, Sony, and Other Camera Brands 76 10-25-2013 03:27 PM
Spotmatic F/A3000 lens switching Tonytee Film SLRs and Compact Film Cameras 3 08-28-2013 02:38 PM
All times are GMT -7. The time now is 03:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
