Originally posted by ChrisPlatt I spent fifteen years using Nikons.
IMO the KX is nicer than the FM/FM2/FM2n, unless you need the MD-12.
OTOH the FE/FE2 is nicer than the K2.
The FM3a is the one I've always lusted after...
Chris
The FE COULD feel a bit small and slightly insecure in the grip you get, on some subjective basis -- a comment you could apply to pretty much all the compact bodies. An even smaller ME Super simply fits into my mitts with fine comfort and control. I couldn't quite get on with an OM-1 back in the early '80's, dimension-wise, stability-wise. So who knew in advance, right? My view is that these days, it is a relatively straightforward matter to customize smaller cameras to your own needs, if you feel you've got a keeper. It's kind of tough to downsize a body, though! This is the age of small scale, one off, personal 'additive manufacturing'... and improved moldable stuff like Sugru. Most folks won't likely wish to do much frame burning with film these days, so the pretty nice motor drive unit you cite could be modded and re-purposed as a perimeter weighted, but still fairly lightweight grip for improved handheld stabilization, perhaps with longer, heavier lenses. This is in fact my own plan -- my MD-12 came in under $10. You certainly won't have to worry about battery drain with an FE!
I have recently found that my F2's seem *much* more "of a piece" and weildable with the F2as style Photomic finder attached... compared to a DP-12, the F2a finder, on top. You wouldn't have expected the subjective difference -- I sure didn't. Little things mean a lot. So generalizations are a little difficult.
As regards the KX, I do know that it gets high marks in the camera database. I'm left-eyed, so... a potential problem there? I know I'm fine with all my Nikons (the smallest, the FG-20, could use a little shaving back of one corner of the rewind lever's plastic end piece to accommodate my dominant eye needs -- no big deal at all. Again, a better fit for me than the slightly larger FG, as it turned out). The interchangeable, modernizable focusing screens of the FE/FM series are a useful feature, too. The view, in any case, is certainly not dark... but still nicely contrasty (unlike the bright, but much harder to focus Olympus OM-1/2n). Nikon just got all the details right; and complete. I'd think a KX guy would like the later Nikkormats. An FT-3 for your auto-indexing lenses... an FT-2 for the older "rabbit ear" classics, perhaps? [Hint: the Canon FTbn is sweet as can be -- if you can live without a split-image finder screen... an issue for me, unfortunately: darn near shockless in action, just a bit ping-y (metallic). Rockwell did a nice write-up not long ago.]
I don't know about the KX's metering pattern. Does the KX just have a "bare" match-needle system, Chris? I really appreciated having a full scale readout of the shutter speeds, especially as implemented in the FE and EL2. I do know that the tight, predictable containment of the sensitive area within the famous 12mm circle on the Nikons just works great, used as I suggested. I practically never missed an exposure with Kodachrome 25 or 64. It's hard to give up on the idea of these film stalwarts, isn't it? Keep having fun! Regards, Fred
Addendum: I've noticed a number of other film-centric posts of yours, Chris. So I am curious: What percentage of your photography would you say is still being done with film? Would you say there's a specialty for 35mm film that still trumps digital for output quality? I have a nice Fuji GS 690 II here now, which I got such a great deal on, and I'm wondering how much use my 35mm cameras might (and should) get at this point. Due to the necessity of waiting out one of life's inconvenient, but common enough forced downtime periods, I haven't been able to really break out the new K3 yet. So I'm kind of uncertain now how all the pieces are going to fit together.
