08-24-2014, 12:02 PM   #1
ikon.st's Avatar
Is there such thing as K to FE adapter?
I tried searching but couldn't find anything conclusive, so please forgive me if this is been discussed before (recently?).
Is there an adapter for a7r, with which I can use pentax K mount lenses and use the entire 36mp (not cropped 24mp)?
If not what is the best K to E out there that is reasonably priced?
08-24-2014, 12:11 PM   #2
Otis Memorial Pentaxian
There are adapters and if the original lens was designed for 35mm film you should not have to use the cropped setting. As for quality/price/features, you might want to send a private message jogiba or hinman. I believe that they both use K-mount lenses on Sony FF cameras.
08-24-2014, 12:29 PM   #3
osv
there are probably half a dozen pk-nex adapters out there.
even the dirt cheap adapters can work well... i found a $10 adapter on ebay, that had a black lens mount area, that really cut down on light leakage at the lens to adapter joint.
don't fall into the trap of thinking that you have to pay $200 to get a usable adapter.
08-24-2014, 12:34 PM   #4
ikon.st's Avatar
Thanks Steve. Does this mean, I can buy one of those K to Nex or E mount adapter and when used with FA or DFA lenses I should be able to shoot without cropping?
08-24-2014, 12:46 PM   #5
I'll just drop in a comment here - that lenses with an aperture ring work best, since there is no way for the camera body to control the aperture automagically, as that is going to have to be a manual operation. Just my 2 cents...
08-24-2014, 01:25 PM   #6
QuoteOriginally posted by ikon.st Quote
The short answer is yes. The adapter question is a little deeper however. That is why I suggested a PM to those who actually know. Here are the pitfalls as I understand them:
  • Quality of machining, inter-flange distance is critical
  • Aperture ring support for those lenses that lack them
  • Potential for light leaks. The machining of the mount faces is critical.
I personally don't think this is a situation where "cheap on eBay" is a good option, though it might work for some. Both of the users I suggested above should be able to offer guidance. I know Hin personally and know that he is a helpful kind of guy.
08-24-2014, 01:36 PM   #7
ikon.st's Avatar
Thank you !!
08-24-2014, 01:45 PM   #8
Na Horuk's Avatar
Yes, keep in mind the aperture thing! Some lenses are really great, but if you are stuck with wide open aperture,.. (this depends on adapter btw, not sure what exists with K to FE adapters)
What this basically means is, that instead of buying a DA 50mm f1.8 (no aperture ring) or FA 50mm (has aperture ring, but you don't need to pay for AF if you can't use it), you can instead get a Pentax M 50mm f1.7. Cheaper, optically excellent, and you don't pay for features you won't use.
Another thing is that DA lenses are made for "crop sensor", but many still project a full frame image circle. There is a thread with Pentax lenses tested on full frame/film.
08-24-2014, 02:24 PM   #9
hinman's Avatar
On Amazon, I got something like these
http://www.amazon.com/Fotodiox-Adapter-Aperture-Control-E-Mount/dp/B005ORIS4...+k+to+sony+nex
http://www.amazon.com/RainbowImaging-Pentax-E-Mount-Camera-Adapter/dp/B00406...+k+to+sony+nex
I bought the brand by RainbowImaging. The above adapters will work for FA and DA lenses. My copy with Lock/Open ring on the adapter has about 5 stages of aperture control that can be used with DA lens. Not all DA lenses will work in FF non-crop mode, it varies depending on the individual lens and if the lens opening cover the full image circle on the FF sensor.
For FA type of lenses that has an aperture ring, I prefer simpler adapter without the Open/Lock ring on the adapter and they usually cost less.
There are some adapters that are better built and they cost more and I have a copy of Kipon adapter with an aperture ring but I dislike the adapter without any marking on Lock/Open. Some adapter work better than other with tight fitting and proper alignment on markings. I will suggest to choose one that is black in interior over chrome/silver in the interior.
A picture of the Kipon PK/DA to E adapter -- I don't recommend highly on this Kipon adapter as it has no markings on Open/Lock but the good thing on this adapter is a tiny bit better build than the other. The cosmetics may appeal to you and if you don't mind to spend a bit more on an adapter, the Kipon is one of brands to consider.
You see the above that has a Pentax FA 43mm f/1.9 mounted on the Kipon adapter sitting on the right next to a Contax Zeiss Planar 45mm f/2.0 mount on a TechArt AF adapter for the E mount.
The most costlier adapter is the Novoflex, which I don't have a copy, but others prefer its quality over the others
http://www.amazon.com/Novoflex-Adapter-Pentax-NEX-Cameras/dp/B00429Z7X0/ref=...entax+k+to+nex
Cheers,
Hin
08-24-2014, 03:13 PM   #10
ikon.st's Avatar
QuoteOriginally posted by hinman Quote
Amazon.com : Fotodiox Lens Mount Adapter with Aperture Control, Pentax K Lens to Sony NEX E-Mount Camera : Camera & Photo
Amazon.com : RainbowImaging Pentax DA lens to Sony E-Mount NEX-3 NEX-5 Camera Mount Adapter : Camera & Photo
There are some adapters that are better built and they cost more and I have a copy of Kipon adapter with an aperture ring but I dislike the adapter without any marking on Lock/Open. Some adapter work better than other with tight fitting and proper alignment on markings. I will suggest to choose one that is black in interior.
You see the above that has a FA 43mm f/1.9 mounted on the Kipon adapter sitting on the right next to a Contax Zeiss Planar 45mm f/2.0 mount on a TechArt AF adapter for the E mount.
Amazon.com : Novoflex Adapter for Pentax K Lenses to Sony NEX Cameras : Camera Lens Adapters : Camera & Photo
Cheers,
Hin
Thank you very much !!
08-25-2014, 10:38 AM   #13
osv
finding a good adapter is the problem.
here are two overpriced novaflex adapters that have serious light leaks:
Bad light leak with Novoflex R adapter: Sony Alpha/NEX E-mount Talk Forum: Digital Photography Review
again... expensive does not necessarily mean better.
here is what a black lens mount adapter looks like... this is canon fd, if you can find it in pentax mount, get it, because that black cuts down on the reflectivity.
Canon FD FL Lens to Sony NEX 3 NEX 5 5c NEX 5N NEX 7 6 NEX VG10 E Mount Adapter | eBay
a hairband around the mount joint can also help.
be aware that sony has a free warranty fix for any a7r mounts that leak light.
"there is no such thing really as professional photographers" Winder Photographic Industry and Professionals 17 06-12-2013 07:21 AM
Is there such a thing as too wide? milka Pentax SLR Lens Discussion 16 07-28-2012 08:10 PM
Is there such thing as a 17-70mm constant f2.8? ismaelg Pentax SLR Lens Discussion 4 06-10-2010 09:13 AM
is there such a thing as a m42 true macro lens ? janstew Pentax SLR Lens Discussion 7 02-20-2010 04:54 AM
is there such a thing as a B&W printer? BetterSense Digital Processing, Software, and Printing 5 09-12-2008 09:14 AM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
