Originally posted by pepperberry farm good morning!
I have one of the K&F adapters with aperture control for Pentax lenses with out an aperture ring - it works, but the aperture control is more of an approximation and is not fine control at all - for this reason, I usually keep those lenses on my K-3....
for a wider lens, I have and enjoy a TTArtisan 23mm f1.4 in native x-mount, but also have a Pentax SMC A 20mm f2.8 that is just a wondrous lens....
Originally posted by Jonathan Mac I also have the K&F Concept adapter and I would recommend it. I've used it with my DA Limited lenses, including the 21mm, with no problems. From memory it gives about six different apertures from fully open to f/22, but that's plenty control for anything I ever used it for.
Thanks very much! Most helpful. I mostly shoot at f8 and leave it there, so I'm sure I can work out where that value sits on the adapter control ring. At $35 it's worth a try. And I'm happy I can use the DA21 with it - wonderful lens. I also have the DA40 Limited, which will make for a nice trio along with the the Fuji 27.
Pepperberry - I hear you about the SMC A 20mm. However, it costs about as much here in Canada as a good used Fuji XF wide angle prime, so not really an attractive option cost wise. Plus I've got that focal length covered with multiple DA lenses for my K3.
I'll order that adapter tonight.
All the best,
Svend
