Originally posted by luftfluss How long did it take you and Photoshop to create that environment?
About 2 minutes, most of which was waiting for Photoshop.
Open image in Photoshop, select subject, select inverse, click edit/ generative fill, enter construction site in the dialog box that opens and click generate.
The software generates 3 backgrounds that match the criteria entered. If you like one, choose it, otherwise choose the one you like best and click generate and 3 more backgrounds pop up. There doesn't appear to be a limit on the number of times this can be repeated.
Pick the image you like best and there you go.
This is all done via cloud processing, so a lot of the time spent will be dependant on how fast your internet connection is as the image is uploaded to an Adobe server for generation and then download back into Photoshop.
This is in the Beta version of Photoshop, and sometimes the results are wonky, sometimes they are just plain bad, but when it works, it works well. I've noticed that over the past couple of weeks the image generation has improved a lot, so it is definitely a work in progress as they refine the algorithm, readying it for final release.
