Originally posted by farhagh No, it doesn't. At least if you imagine a 200mm attached to a m43 vs a 400mm attached to a FF body. For sure m43 will have it's limitations but it's good enough in many cases. That's exactly why I'm not interested in FF & APSC MILCs; if I'm going to carry 2Kg of a lens, why should I care about 200gr extra for the camera? Just to give up the OVF?!
That's the dilemma of mirrorless. If you have to shoot with large lenses (and some of us do), and you're either indifferent to the whole EVF vs OVF or you actually prefer OVFs, then what's the point?
In theory, you can at least mitigate the big lens problem by going to a small sensor, which is where m43 should have (and sometimes does) have an advantage. But it hasn't always worked out that way. The Olympus Pro lenses are really quite large and heavy, and they don't always scale so well when compared to FOV alternatives with APS-C DSLRs and FF mirrorless. The Olympus Pro 300 f4 weighs almost a half a pound more than the DA* 300 while costing almost 2 and a half times as much. While the Oly 300 gives more reach, add the 1.4 TC to the DA* 300 and it will give you more reach while still weighing less. That Oly 300 also weighs a quarter pound more than the Canon 400 f5.6 which, when mounted on an APS-C camera, provides the same FOV.
The Oly Pro 7-14 f2.8 weighs more than the DA 12-24. It weighs about as much as the Sony FE 16-35 f4. While the Oly does provide a bit more width in its FOV, you're gaining nothing at all in terms of weight savings. Indeed, if you compare the E-M1 with the f2.8 zoom trio with a Sony FF mirrorless and Sony's f4 zoom trio, there's not much difference in either weight or size or even price, yet the Sony f4 trio is matched to a sensor almost four times as large.
Of course, if you're willing to shoot with primes or slow aperture consumer grade zooms, there's plenty of quite small options available in m43. If you wish for pro quality zooms, you may be better off with a larger sensor format.
Originally posted by 6BQ5 The M10 right now comes pretty close to the performance of our K-3. From DXOMark
From my experience with the E-PL1 and the E-M5, I find that the DXOMark scores for m43 cameras somewhat exaggerate their real world performance. The E-M5 attains a higher score the the K200D. But in real world performance, I don't really see much difference in these two cameras. And at ISO 100, the K200D produces cleaner files with richer, more beautiful color. Meanwhile, my K-5 has anywhere to a stop to a stop and a half ISO advantage over the E-M5, and considerably more dynamic range as well.
