Hello,
I have just received my Lens Turbo II in K mount and have tested my FA43 and Volna 50/1.8 lens with it and my Sony a5000. However I am a bit confused with some of the math regarding aperture in terms of light intensity, and the DOF.
As I have read, the Lens Turbo II is a telecompressor with a 0.73x crop factor, and the 135 equivalent focal length of my Volna 50/1.8 with Lens Turbo II should be 50mm*1.5*0.73 ~= 55mm. This is what I am sure about the Lens Turbo II.
Some reviews say that for the equivalent aperture in terms of light intensity, it works like f1.8*0.73 ~= f1.3, however when I research on the Nikon E-series, which also used a telecompressor, I got:
Quote: The E series uses a unique additional optical system that enables the small sensor to capture the field of view of a 35mm film, with a crop factor of 1. This comes not at the expense of the lightness of the lenses, because the light is bundled to the 2⁄3 inch CCD sensor with approximately 1⁄16 smaller area. The result is approximately 4 stops (2^4 = 16) more light at the small sensor compared to a full-frame sensor. Therefore the camera has a minimum full-frame sensitivity of ISO 800 which is equivalent to ISO 50 at 2⁄3 inch.
Now I am not quite sure how to work out the equivalent aperture in terms of light intensity.
Finally, I found next to none useful information on how to work out the DOF when using the Lens Turbo II. Some say the hyperfocal scale will line up others say it will not. And also no information on how lens correction profiles will behave.
Any information will be welcome.
Sincerely
