Rubbing alcohol, which audio specialists caution people not to use to clean the rubber rollers in tape decks and some record turntables (because it can dry out the rubber) is exactly what you need. Last fall I purchased a Sigma AF zoom on which all of the rubber gripping surfaces had started to become sticky (absolutely the ONLY thing that was wrong with the lens), and a few careful treatments with rubbing alcohol completely removed the stickiness. The rubber now has more of a lustrous finish, however, not flat pebbly finish that it originally had. A very minor downside, considering the grip surfaces are not sticky anymore.
You might find the procedure a bit time consuming or tedious, but all it costs is time. I put some rubbing alcohol in a bottle cap, and then dipped a cotton swab into it and then let any excess drip back into the cap. It is good to start with one of the wider rubber areas so you get used to controlling how much the alcohol spreads out. You don't want it getting off of the rubber and seeping into cracks between other parts of the lens body. Also stay away from areas of the rubber with painted imprints, since the alcohol might remove those. After you dampen an area of the rubber with the alcohol, gently, gently, scrub the surface with the swab. Then do another area. Use a new swab when one gets more than a little gray from the stuff coming off of the rubber. You'll go through quite a few swabs. I let the lens sit and the rubber dry out between each grip ring I worked on. Then, after all three were done, I may have waited a whole day Then I looked at how it turned out and felt for remaining sticky spots. I retreated those sticky areas. Also on this second treatment, I got closer to the little bit of painted lettering that was on one of the grip rings of my Sigma lens, and I worked closer along the edges with a less-damp swab to keep alcohol from getting away from where I wanted. Again I let ieverything dry for several hours. For the last and final alcohol treatment, there were only a couple of tiny areas that needed a bit more work.
