Originally posted by serothis The article recommends hand held at shutter speeds 1/2*focal length. Specifically that the natural hand movement acts at the "pixel shift". That means you can't do any tripod work. So images like the below are impossible. It also suggests that higher shutter speeds plus burst mode would be less effective.
This is a method of spatial oversampling. The same method is use in high speed oscilloscopes where the same signal is sampled by multiple channels each having a sampling clock is phase shifted in small increments. So, for example, if the same signal would be sampled by 4 channels, each channel with 90 degree phase shift, the time resolution is 4 times faster than the time base of the scope.
How does that related to super resolution with multiple shots aligned? It is the same technique as spatial over sampling used by high speed scopes. The difference being that the phase shift is random, but each photo should be equally sharp. So , shooting at 1/2*FL would add some blur and it's not good at all. However, shooting on tripod is not a problem is the camera position is moved for every shot. Also, even 20 shots is not sufficient to ensure evenly spread camera position, 30 to 50 shots would be better to achieve super resolution on the basis of random camera position.
Between the constrain of very stable tripod for a sequence of 4 pixel shifted images and shooting a few dozens of shoots, I don't know what method is easier, IMO both method aren't as straightforward as a single shot.
Anyway, as I wrote in anther thread, unless printing XXXL, for the rendering of an image, more resolution is pretty useless compared to the use of a larger sensor, however, more resolution makes camera slower to operate while lower pixel count on a larger sensor brings better images at fast speeds.
