Panasonic G85 Help!!! - Crooked Sensor
Hello,
I was using my Panasonic G85 the other day, when I realized that the viewfiender/pictures had a slant at the bottom of it. I thought maybe it might be a problem with the lens, but further inspection revealed that not to be the case. Possibly a problem with the IBIS, but it appears to be working. Then, after looking at the body/sensor without the lens on, and you can visually see that the sensor is visibly off a bit. I don't understand what changed between now and the last time, or why you would want your camera to be able to change it's sensor position...
I was wondering if anyone had an explanation or a way to fix it????
Would be a big help!
Best,
