Originally posted by D1N0 Optical lens size is rather small. I don't see why it has to come in such a large package. Lens motors don't need to be so large.
Since the filter thread plane is positionned in front of the lens front element by a certain distance rather than having the fitler thread plane aligned with the lens front element plane, the lens filter thread has to be large enough to let enough clearance for the angle of view of 20mm so that 3:2 rectangle corners don't end-up shaded, regarless of the maxium size of lens aperture. Diagoanl angle of view of 20mm on FF is 94.38 degrees, just draw that 94.38 angles lines from the lens optical center and you get how large the filter thread should be.
---------- Post added 30-10-19 at 12:16 ----------
Originally posted by Dan Rentea Why were you dreaming about 20mm and 85mm lenses?
On the one hand, I'm dreaming of 20mm and 85mm. On the other hand I'm glad they aren't available for the K mount, because I don't need those lenses and the lack off them saved me money.
