Originally posted by Rondec Z6 and didn't feel as though it could keep up with the KP due to PDAF banding issues
banding issues can be a problem when pulling shadows, although this can be mitigated by using an ND grad filter or bracketed exposures. The annoying photographic case is when doing very long exposures (2 minutes sunsets or longer) when it is not possible to bracket. The S1, S1R is the FF milc that doesn't use PDAF on sensor , but is as big as a K1, still Pana L mount will have more interesting lenses than Pentax by the end of 2020 (3 primes and f4 zooms from 16 to 200mm).
---------- Post added 05-03-20 at 15:11 ----------
Originally posted by jcdoss The Z7+lenses are a significant weight savings over the Pentax, and in fact the hugeness of the DFA zooms might be the main reason I never purchased one.
Good point. The dilemma for me is the form factor. Z6/Z7 is small but the primes are big, so if I stick an FA35 f2 on my K1 it's actually more compact than a Z7 with a Z 35 f1.8 S lens, weight is about the same, but holding the K1 with FA35 2 actually feels better than holding a Z7 with a Z 35 1.8. Ricoh seem to be missing the plot with lenses such as the DFA*50 (big like Canon or Nikon) while Pentax had the small primes for film. Practically, a Pentax K1 with a pancake prime fit better in my bag than a mirrorless with a large lens, form factor is the key here, just trying it out makes us realize the difference. IMO Ricoh should roll out 20mm f4, 35mm f2, 50 f2 and 85mm f1.8 compact glass and so far I haven't seen anything like that apart from adding a green ring to the FA35 2. I just feel like Ricoh are playing lazy with regards to Pentax.
---------- Post added 05-03-20 at 15:37 ----------
My ideal Pentax K1 primes set wishful thinkin:
- all metal build like the DA limited look, black & silver
- 9 blades rounted
- HD coating
Focal len. and apertures.
- DFA 20mm f4
- DFA 35mm f2
- DFA 50mm f2
- DFA 85mm f2
Compact size, weight: < 500gr (300gr for 20mm, 35mm, 400gr for the 50mm and 500gr for the 85mm)
Sharpness: sharp in the center wide open , sharp at f2.8, and tack sharp across the frame by f4
Initial price: $499 / 499 euros (cheaper and smaller than canikonsony)
Affordable, perfect prime kit for the K1 & K1 successors (if there will be any..)
