Originally posted by pimpim yeah tried that, thing is that this shows quite a few uploads from back in the early 2010s, so lower res uploads or where people still photoshopped the hell out of their JPEGs and called it SooC anyway
Anyway, thanks for the suggestion I took a second look and it seems promising. Getting focus right will be the hardest part probably, but for a low-cost full frame set-up it might be fun.
Do you already have some Pentax FF-compatible lenses? Factor in a couple for Canon.
I came really close to buying a Nikon Z5 to add to my repertoire. After looking at the total cost for the camera, even refurbished plus just two quality lenses, it just didn't make sense for the relatively minor benefits I'd be getting over my already very good Pentax stuff.
By sticking to one manufacturer you can afford far better gear than by mixing and matching and duplicating for two. Not getting the Nikon allowed me to spend on pro-grade glass for my Pentax's and still save money overall. If being thrifty is your goal I'd suggest buying a K1 which will cost you $900 or thereabouts. If the money is less important than the fun of playing with a different brand I'd say go for the Canon. I'm seeing them at readily available at $500 give or take so certainly cheap enough for the body itself.
